asimpson
- Aug 6, 2010
- 300
I am lookig for magnet wire 20 awg copper to run continuously over 400 deg C, 900 F. at 300 V AC.
I need a thin coating like on traditional enamelled wire so that I can wind it into a tight coil. Polyimide insulation is only rated for 240 C continuous use.
I am considering ceramic coated wire which is good for the temperature but may be sensitive to moisture which may be a problem.
Any help welcome.
Any help welcome.
