High temperature valves
itsmoked
19,114
I'm not having any success finding high temperature valves. As usual I'm probably not calling them what the industry might.
I have to closed-loop control the temperature of two rollers and an asphalt tray. They're heated with 440°F/230°C oil.
I need some sort of analog style valves of about any kind that will put up with that heat. Motor operated might make the most sense? Something around 3/4" to 1".
What do you know?
Keith Cress
kcress -
There is nothing challenging about your application. Usually the actuator is separated from the high temperature by a long stem. There was a manufacturer that made pneumatic operated diaphragm control valves that was so ubiquitous their name became a coloquialism for control valves but I'm drawing a blank on it right now. This type of valve is likely what you're looking for.
Consider posting in the "Valve Engineering" Forum for better sets of eyes ....
MJCronin
Sr. Process Engineer
Fisher is the iconic name in control valves, now owned by Emerson.
Link
440°F oil isn't particularly challenging in terms of sealing. Heck, these are control valves so they may not even need tight shut off capability. 440°F is certainly above the flash point of most oils I come across. In that case some sort of backup seal and leakage monitoring may be necessary.
Dreamchaser,
Every post you have on these fora suggest machinable glass ceramic as the answer to people's woes. You admit in another thread you're helping a buddy market the material. These fora are not your personal marketing venue.
Dan - Owner
Tug; Are these things usually globe valves?
MJCronin; I did not know a valve forum existed. Well dang, it's fairly active even.
Dan; Swear I tried that with useless results but "hot oil valves" is working pretty good. Thanks.
danw2; I've used Fisher many times, only for water though. Did not know they'd been slurped up by Emerson.
Keith Cress
kcress -
