stephanemunger
I'd like to find a high velocity furnace capable of delivering high static pressure. This is for a high-end residential application where I would like to conceal a duct which would be ideally as small as possible.
I've looked into the Unico system, which from what I can gather is not truly a furnace but a fan coil unit with a high velocity blower. It still only gives up to 2" W.G. static, which is in my opinion marginally better that the 0.8" W.G. I'm getting from a standard G61 Lennox furnace.
My specs are 80,000 Btu/hr, so approx. 1300 cfm depending on the temperature rise. I have a duct run of approx. 100', including all elbows. I was hoping to use a 6" round duct, even a 4" if at all possible, but I know this is pushing it quite a bit. So I'm looking at least 12" W.G. static. Is there any off-the-shelf high-velocity furnace capable of doing this ? Thanks in advance for your help everybody.
