high volume very low head pump
dcasto
Chemical
I'm looking for a 50 gpm 1 to 2 feet head water pump. I was hoping to find a screw type to power in a ditch and raise the water up to a new ditch that I could use with a small solar panel. Once i find the pump, the conversion to solar is not a problem.
A wonderful invention making use of the water hammer / surge pressure to charge up the cylinder.
"ram IMO refers to some precompression going on, as would a ramjet engine"
Well, it is kinda like a ramjet, in using the incoming velocity head to create pressure. Only different. Surge pump would be a fine term to, if it didn't remind me of milking machines. Water hammer pump would be a good description, but would likely scare people.
Mike, I do agree that some kind of weir and flume would need to be provided for the irrigation scheme, and a bigger question is how large the pump would need to be to provide 50 gpm.
My concern would be that with a ram pump, in order to send 50 gpm up, you need to send 500 gpm down. No 'down' was mentioned in the OP.
IMHO, still, something like a small scale model of a Wood Screw Pump would be a decent choice for this application. ... except that I'd put the screw in the low leg of the syphon, not in the crest, so you wouldn't need a vacuum prime to get started.
Mike Halloran
Pembroke Pines, FL, USA
The great advantage in both capital and operating cost is that you need no outside power source.... even if volumetric efficiency might be only 1 in 10, probably dependent on the ratio of lift head required to velocity head available. If that's all the water and the head that you need, a ram or "impulse pump" is no brainer.
Let your acquaintances be many, but your advisors one in a thousand’ ... Book of Ecclesiasticus
