EngDM
- Aug 10, 2021
- 522
Hey all,
I am playing around with the Profis Diaphragm designer, and I am coming into an issue regarding deflection calculations. I have emailed Hilti about this, but I'm hoping someone here might have a quicker answer since Hilti appears to be on vacation.
To prefice, I have always thought of a diaphragm as a deep beam. By analogy, the equation for diaphram deflection is some form of 5*wl^4/(384EI). In Hilti's documentation here on page 17 (section 6.2) it lists what the variables L and b are (with respect to the deck direction). Since they show L as being dimension perpendicular to deck flutes, that means they take length as your joist length (or plan dimension parallel to joist). However, joists are not necessarily always spanning in the short direction of your overall building (see below screenshots):
Is it not more accurate to list L as your length perpendicular to wind direction, and b as your dimension parallel to wind? Like as far as deflected shape does, the diaphragm doesn't care if the joists are spanning east-west or north-south, the deck is still spanning from my lateral support elements, in this case cross bracing at the end walls.
