Ho to create a circle section on a hollow cylinder? 1
mdama
Materials
Oct 12, 2018
118
Hello
I was wondering how I can create a circular section (partition)on a non flat surface like a hollow cylinder?
If you select Partition Face: Sketch and pick the cylindrical surface, you will be asked for sketch plane (use datum plane tangent to cylindrical surface). After that you have to specify the projection distance and direction. Sketch a circle and it will be automatically projected creating partition.
