PreludeEdge
Is there a way to select many holes in Hole Milling Operation?
We use NX8 and found a way to select many hoes with the same diameter with Synchronous "Group Face" BUT I can't use it in Hole Geometry. Also I can use color filter for many holes but how to color many holes with the same diameter avoiding manual picking every hole face in "Edit Object Display"?
Thank you
Thank you
