Hole dimension leader
enuf4u
8
Is there any way in wildfire 2.0 to dimension a hole (diameter not radius) and have one leader with one arrow? It currently displays two arrows 180° apart either pointing at the interior or exterior of the hole.
Thanks in advance
When I FLIP ARROWS all it does is change the direction the arrows are pointing. The dimension leader still has two arrows; one on each side of the hole; Inside pointing out or outside pointing in. I basically want a leader (one arrow like the radial dimension shows, but I want a diameter dimension), but I want the dimension on the drawing to update when the hole in the model changes.
Thanks for the quick response
I found what my problem was... In Drawing Options, set Text_Orientations to: parallel_diam_horiz; mine was set to parallel. After I done this, the flip arrow choices gave me my desired leader.
Thanks!
