Hole Tables - NX11
BrittToolEngineer
Aerospace
Greetings:
I have to submit, the designers of UG should be ashamed of parts of their software. For example, Hole Table. You get the verbiage generate how UG sees fit, when you modify the table to read how you wish it to read, then the table is updated at a later date, the original information reappears. Really? Why? Seems easy to fix. Moving the table around with a portion of the table having to separate, the two do not cooperate with one another. It's like the simple hole table took a step back into the 1960's. Please UG, fix the hole table command, for the love of efficiency.
Brent
Remember that this isn't a forum which is monitored by Siemens NX development or support team.
If you want to have some influence on how NX is functioning, be able to suggest improvements and whatever...Sign up as a Beta tester.
This gives you the possibility to directly state your grievances and improvement suggestions to the developing team.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
Awesome NutAce, thank you for the reply. I was very frustrated yesterday and wanted to shout. ;)
hehe...understandable :)
NX9 / TC10.1.2
