Hole wizard rounding decimals 1
jfoxx
9
I have Solidworks 2011 and it is rounding the decimal place for holes and angles.
I'll input 3.875 and it will show 3.880 when I put it to three decimal places.
For angles when I use a 45 deg angle it won't show any zeroes (like 45.00 deg) only 45 no matter how many decimals I set it to so I have to override the value.
I have to use linked dimensions. Thanks.
BTW it only does this for the hole depth.
For your angle issue: with a part template open, go to Options->Document Properties->Dimensions and change Trailing Zeros to 'Smart', or 'Show'.
I'm not sure why you're having the rounding issue. You might want to ask your VAR, assuming you're on maintenance.
Jeff Mirisola
Director of Engineering
M9 Defense
My Blog
I am a coop. Thank you the angle fix worked. I found it odd it only did that for 45 degrees and not the rest. Whenver I input the decimal i immediately rounds it in the property manager and when it shows on the drawing it shows the round with a zero at the end. 1.875 > 1.88 > 1.880. No one else has seen this before. I have tried restarting.
