holes partern problem
Hi
Anyone out there can help me with this problem
I have a part with 45 deg. cut and I want to add 5 holes
vertical with part, the depth of the holes must be equal depth of the 45 deg. cut surface. but the bottom of the holes must be horizontal.
thank you
2433,
If you can define a plane at the depth of the 45 degree cut, you can place your sketch there, and do a through-all cut to the top surface.
Having defined this plane, you have the alternative of sketching and cutting down from the top surface, to your plane.
JHG
