Holes representation
JeniaL
547
I'm looking at Europe Aerospace giant files and i can't understand how holes are created. There are no sketches, no points, no nothing.
I really liked the way they represent holes. I have several models with more than 1000 holes and it's a nightmare if i have to change something inside 3D. It takes forever to update the drawing.
Any thoughts will be really appreciated.
Cheers,
Jenia ladkov
Thanks. I believe they use both (fasteners license and CAA apps.).
I don't know, don't dismiss the cost of these things, automotive body-in-white fastening is maybe 20K$ for one license. And P3 platform only, which is another significant added cost. So, big company...small company. All will prefer to screw around instead of investing in software when the pricetag is that steep. The fact that you don't even know for sure definitely already shows a lack of proper supplier communications.
Another day in the life of an inefficient world!
JeniaL, its called HnF plug-in (if I remember correctly), it was developed special for Airbus (hope I'm not wrong [smile] ) , and you have points and surfaces where you have to define all those final holes...I worked with that and is pretty easy to use it...with a little knowledge of programming, I believe it can be developed something similar but a little bit simplified...
Fernando
- Romania
- EU
Ferdo you are absolutely right.It is Airbus. I can see no links to other geometry inside CATPart.
I believe such Giant may invest 20k and even more for a seat.
You don't need links (in fact, you don't want them when you have huge assemblies in VPM and you need to load for different purposes, it will take for ever this action if you will have links for each fastener...). All informations are in those parameters, even the part numbers of the parts tighten, thickness, everything. I don't know the price but those giants can afford, anyway they have discounts...
Fernando
- Romania
- EU
Developed specially for Airbus? Hmm, I'm not a fan of such things. Commercial off the shelf is the only way to go. I'm willing to bet my life Syncrofit is a superior solution.
