TekEngr
- Feb 4, 2012
- 148
Does 150 mm thick non load bearing hollow block outer wall is suitable for the height of 3.5m, however wind pressure is 1 KN/m^2 or I need to provide some lateral support to the wall if answer is yes then by providing the horizontal dowel bars (8mm dia) between wall and RCC column at 1m intervals is reasonable solution as shown below?
Column spacing is 4.5 m
or any other way to provide lateral support???
