moyseh
- Sep 19, 2021
- 37
Hi all,
My query is regarding the hollowcore flooring system which is prevalent in NZ. My understanding is that this item is an industry wide issue and there's currently work being done to investigate retrofit options. Is it fair to say that some of the newfound failure modes only happen at higher drifts and not for lower seismic zones/one storey structures etc?
Furthermore, are there any approved retrofit strategies for the negative moment failure mode? My understanding is that sometimes you can make this failure mode worse when trying to add angles for the Loss of support(LoS) failure mode.
Would be interested to get any thoughts.
