BAGW
- Jul 15, 2015
- 392
I have a question regarding horizontal brace attached to beam web with a welded gusset plate connection. See image below. In such connections, do the plate and weld need to be checked for the eccentricity from the bolts to the weld? If yes, can I assume the eccentric moment will be resisted by plate and do the beam check for just the shear force along the web?
