PSUengineer1
- Jun 6, 2012
- 150
Please reference attached photographs, thank you. I am looking to gather information in regard to a two-story, double-paned foyer window with interior ledge above a front entry door that displays a horizontal crack in one of the windows and some fogging between the panes in another window. I am comfortable with the cause of the fogging between the panes. I am more interested in gathering information on the horizontal crack of one of the windows. The window appears to have possibly been installed out of plumb based on the lack of apparent tearing displayed in the vertical beads of caulk between the brick veneer and the window frame. The window was installed in 1992. I am trying to gather information to research so as to come up with a conclusion in regard to the reason for the crack in the window. The crack was noticed in early spring 2014 following one of the fiercest winters in recent history (polar vortex; northeastern portion of U.S.). The unit is leaning inward, toward the home’s interior as was measured with a 4-foot digital level.
