Once20036
- Oct 7, 2008
- 533
To start, I think I've got a solid understand of VQ/I as it relates to horizontal shear in steel beams. I woke up feeling well versed on the subject and spent a couple hours reading some amazing discussions here on this forum.
So here's the question: Has anybody ever witnessed a horizontal shear failure of a steel beam web?
It's easy to imagine a shear failure of the welds connecting a web and flange (typical application for the equation) but let's say that you have a custom built plate girder with sufficient welds connecting the web and flanges and some vertical stiffeners to prevent web buckling,. Max horizontal shear stress occurs at the neutral axis near the ends of the beam. Is there some other failure mode that typically precedes a horizontal web shear failure? Has anybody ever seen this happen?
