btrueblood
- May 26, 2004
- 10,010
Has anyone had experience with hoses operating (at least some of the time) with an external pressure higher than the internal pressure? I have a device that will be operating submerged at up to 100 psi, and I need to plumb fairly low pressure fluid into it (typically 25 - 30 psi above the case pressure) via a flexible connection.
