I encountered an end-suction installation, 2+1 pumps in parrallel, pumping clean water from a ~27'C makeup source. It is a closed hydraulic system and the pumps have a VFD. The pump in question was running at 50Hz for an hour and the motor enclosure was too hot to hold. I'de say 40-50'C.
I checked and found that the selection was 40-50% efficiency from the pump curve (I know its a terrible selection).
I don't know what to make of the motor enclosure temperature, is it because of the poor effieciency, what is considered a normal temperature rise?
I haven't checked the current yet but the contractor ensures that it is below max. rated. Pumps are rotated and the issue is common to all pumps. The volute sounds quiet; no signs of air entrainment/cavitation and most of the noise is from the motor (78dB standing right next to it). Pumps = 36lps@3.5bar each.
Much obliged to all feedback.
