Ahmed Elarbagi
Petroleum
Hello everyone.
If you have a hot oil (petrotherm for example) closed system with a direct fired heater heating a few end users, such as a condensate stabilizer for example. Is there a best practice in terms of the hot oil operating pressure being higher or lower than that of the end user?
Higher: If the hot oil system pressure is higher, you gain the benefit that if you have a tube rupture in the stabilizer, you will have the hot oil leaking into the condensate, not vice verse, as if the condensate leaks into the hot oil, it will flash and possibly affect the circulating pumps. It could also expand greatly, find its way to the expansion tank, pop a psv and go to a pop tank, and then into the atm, then possibly absorbed by the heater leading to an explosion.
Lower: However, having it higher is much more expensive, as this could change the HO system pressure from 20-30 psig to 200 psig. You're also risking the hot oil contaminating the condensate and no way to get it out.
Is there a standard you all see in terms of which is higher?
