Can we get 2inch branch from 4inch header with Hot Tapping?
our fluid is not flammable.
Do we have any limitation for size of header and branch.
I have seen Api-2201 , but I could not find the limitation for sizing.
So long as you can get a split tee to those dimensions.
I don't think anyone does a like for like, i.e. same size branch as header size hot tap as your cutter head and the piece removed from the branch is simply too big.
For final confirmation you really need to talk to a hot tap company such as TD Williams.
At that size I would have thought it much better to shutdown and install a tee or weldolet.
An NPS 2 on a NPS 4 hot tap should be easily done provided that you have the room for the tap and the machine. As others have pointed out, a weldolet welded to a WNRF with a full port flanged valve is probably the way to go. At that size you'll be using a hole saw type cutter rather than simply drilling the hole.
You're already familiar with API-2201 so that's a good start. ASME PCC-2 2018 will probably have an article dealing directly with hot tapping. For now, the 2015 edition has some indirectly applicable articles (e.g. Article 2.10 about in-service welding) that you might find of some use as well.
