Hello Everyone,
I tried using the search on this website for this topic but I came with hundreds of hits. I love this website but the search isn't the best.
My question is in regards to the efficiency of a hot water boiler as a function of boiler feedwater rate. We have two hot water boilers that run at low firing rates right now, <20%. They are sized for a complete system, and we are less than 1/6 of the way there. Note, these boilers never run at the same time.
However, our boiler feedwater pumps are running at 100%, all the time. I would think that not only is that excessive pump horsepower consumption, but that it would also reduce the efficiency of the boiler because the water flow through it far exceeds the requirement.
I'm told that pump flow through the boiler has no bearing on the efficiency. This seems reasonable in typical operating conditions, but in low firing rates like this, I am not sure if it still applies.
As always, I'd appreciate any feedback.
