KevinNZ
- Jun 12, 2003
- 829
Hi
What's a good reference for working out the flow of hot water from an open ended pipe. The upstream pressure means the flow is critical and hot water will flash to two phase at the discharge.
Thinking of dividing the line into segments and working out pressure drops and the flash point. Iteration required.
Thanks K
Thanks K
