Can someone tell me why my cold water pressure is greater than my Hot water pressure as it comes from the spigot?
My tank switch is set at (off-60PSI) and has a differential pressure of (10 psi).
I've taken the hot water tank check valves out and inspected them for sticking or clogs but found them ok, I even for the sake of it replaced the hot water check but stimm pressure is lower on the hot water side than the cold. I'm at a loss.
