Hotkeys - how to go to main assembly 2
Bombas
Industrial
PL
Good morning everyone!
Is there any hotkeys to go to main assebly, from any part or subassebly?. I mean I have open in Catia window with assembly, this assembly have got large tree structure and I work for example in one part. I need hotkey which lead me to main assembly. Normally I have to scroll all tree to up to main assembly and then double left click with mouse.
one, (very good way imho), is to open up "Open Sub-tree", accessed by right click... you can have multiple sub-trees open, on any level...
regards,
LWolf
The Collapse All command will collapse your tree. I use this often and set a hotkey for it.
This will allow you to scroll much quicker.
Thank You for answear. Function collapse all I have known. Sub tree is interesting Idea for that.
My Catia doesn't have "Sub tree".
I dragged it from "Customize", but it is not active in either CATPart or Product....
How could I make it active?
CAD 2015
Select the node on tree and then RMB.
You should then see an option to open subtree.
Thank you RickyT!
Still, I can't see the difference between the tree and the "Open Sub-Tree.........
What good could I get from this tool?
CAD 2015
you can open up the tree in kompressed form as a sub-tree... and have it like that in that little window. no matter what you do with the "big" tree, the little one stays the same...
regards,
LWolf
