How can a macro detect which sketch is in edition 3
TiagoFigueiredo
Industrial
PT
I,
I want to create a macro that needs to detect wich sketch is open in edition. My idea is to change something in that sketch. Any idea?
Tiago Figueiredo
Tooling Engineer
i had the feeling searching for sketch origin on screen would give me the origin of all sketches but it seems it return only the origin of the open sketch.
so why did I spend some time to check the screengrab image?
Code:
Sub CATMain()
    tempfolder = Environ("Temp")
    filenames = Array(tempfolder & "\initial.jpg", tempfolder & "\usual.jpg", tempfolder & "\lowlight.jpg", tempfolder & "\no3d.jpg")
    Set oViewer = CATIA.ActiveWindow.ActiveViewer
    oViewer.CaptureToFile catCaptureFormatJPEG, filenames(0)
    CATIA.StartCommand ("Usual")
    oViewer.CaptureToFile catCaptureFormatJPEG, filenames(1)
    CATIA.StartCommand ("Low light")
    oViewer.CaptureToFile catCaptureFormatJPEG, filenames(2)
    CATIA.StartCommand ("No 3D Background")
    oViewer.CaptureToFile catCaptureFormatJPEG, filenames(3)
    initvalue = FileLen(filenames(0))
    usualvalue = FileLen(filenames(1))
    lowlightvalue = FileLen(filenames(2))
    no3dvalue = FileLen(filenames(3))
    ' checking which file is the same as the initial state
    solution = 0
    If initvalue = usualvalue Then solution = solution + 1
    If initvalue = lowlightvalue Then solution = solution + 2
    If initvalue = no3dvalue Then solution = solution + 4
    CATIA.StartCommand ("Fit All In")
    Set oSel = CATIA.ActiveDocument.Selection
    oSel.Clear
    On Error Resume Next
    While oSel.Count = 0
    CATIA.RefreshDisplay = True
    oSel.Search ("Sketcher.Origin,scr")
    Wend
    On Error GoTo 0
    Set oSketch = oSel.Item(1).Value.Parent.Parent.Parent
    oSel.Clear
    MsgBox (" the sketch is " & oSketch.Name)
    ' restoring initial visu
    Select Case solution
        Case 1
        Case 2
        Case 4
        Case Else
        MsgBox ("Can't be sure about initial sketch visu setting")
    End Select
    For i = 0 To 3
    Kill filename(i)
    Next
End Sub
Eric N.
Fernando can you add this to Catia Portable Script Center next version?
Eric N.
whow... I'm feeling so little near you guys... You are really far away from my level. I really have a loooottttt to learn...
Really thank you guys, from your support.
Tiago Figueiredo
Tooling Engineer
