This is for a new product I am designing, which involves topping-up or refilling the liquid into a CNC Machine or Part Washer.
I have to mix about a Litre of the chemical (alkaline.. pH in the range of 8-12) with about 50 Litres of water. The water will be fed under gravity through a 1" pipe, while the chemical will be pumped either from a Chemical Barrel or a Tank.
Flow-rate of both the chemicals will be controlled with the help of flow sensors & valves.
Now, my question is how do I achieve mixing of both the chemicals to produce a homogeneous mixture? The objective is to do this in-line without use of an additional Tank & Agitator. I have pondered about using a Static Mixer or an Injection Quill, but I am not convinced I'll get a homogeneous mixture from these.
Request somebody with prior experience on similar fields to suggest or guide me towards a solution.
KV
KV
