How can I add text in a ppt? 1
iscariot
154
I found how add Picture inside a ppt in below thread:
[link ]
[/url]
But I would need also to add a text from a catscript. How can I do this? I tried like below but it does not work:
Code:
ppt.ActiveWindow.Selection.SlideRange.Shapes.AddTextbox(msoTextOrientationHorizontal, 100, 100, 200, 50).TextFrame.TextRange.Text = "Test Box"
Thank you.
You are right, I could do it like you told but it is not exactly what I need. Off course, if no other way than I will proceed as you told.
I would need more control on the ppt in order to make it automatically using the company standard to be sent to our customer.
I want to make it a little bit more complex, with more functionality, but I was stuck just from the beginning with adding a simple text :)
Should be possible to add a text in a ppt using a catscript?
Is this what you want?
if it is:
Code:
PPT = PPT.ActivePresentation
            Dim SlidesCount = PPT.Slides.Count
            Dim oSlide = PPT.Slides.Add(SlidesCount + 1, Powerpoint.PpSlideLayout.ppLayoutTitleOnly)
            With oSlide.Shapes.Item(1).TextFrame.TextRange
                .Text = TextBox1.Text' this is the string that adds the text
                .Font.Name = "Eurostile LT (Headings)"
                .Font.Size = 48
            End With
Tiago Figueiredo
Tooling Engineer
Thank you TiagoFigueiredo, this was exactly what I was looking for :) .
I updated the intial code with below code inside a catscript:
Code:
	uNewS.Layout = 4 '12 means no text / 4 means title only
Code:
        With uNewS.Shapes.Item(1).TextFrame.TextRange
            .Text = AnnViewName 'this is the string that adds the text
            .Font.Size = 48
        End With
Now I need your help. One of my collegues is trying to do this for NX. wich is very simillar to CATscript.
How do you call PowerPoint?
Tiago Figueiredo
Tooling Engineer
