Mecheng29
- Aug 16, 2011
- 5
Hi All,
I have to design an atmospheric tank with a vent (goose neck type. The tank is being field to almost 2/3 of its height with flow rate of 194 gpm. How can I calculate the size of vent I need?
194 gpm = 26 CFM
if I choose 3/4" SCH40 vent then velocity of air will be 141 ft/sec. does it mean that in this case air inside the tank will be compressed during filling stage and pressure develops(or vaccume happens during discharge), or it only means air will be discharge at high speed with noise but without developing pressure inside?
194 gpm = 26 CFM
