How can I get a File Name in Sketch?
tpalsl125
Automotive
DE
Hello, all
I'm trying to make some macro.
But I didn't solve to get a file name in Sketch.
ALSO I know how to get a Catia Name(Part Number), a Instance Name and an object name in Sketch.
But I don't really have no idea to get a File name in Sketch.
Can somebody help me or give me some tips?
Please explain what you mean by "file name in sketch". Do you want the part's number to appear in a sketch so it can be embossed/raised on a part in 3D?
Hello, lardman. Thanks for your reply.
I meant, when I am in "Sketcher" Mode and select an element(Point2D, Line2D, etc..),
how can I get a File name? Not Catia name(Part Number) and Catia instance name.
Here is my script which I found on Google and I modified a little bit.
Of course, I know the 'FullName' method can get a full path of the part when I select only 'Product'.
But I want to get a full path or file name only when I am in "Sketcher" mode.
Could you help me solve this point?
Code:
Set Sel1 = CATIA.ActiveDocument.Selection
Set SelObj1 = Sel1.Item(1).Value
MsgBox "* Type Name *" &Chr(10)& TypeName(SelObj1)
MsgBox "* Instance Name *" &Chr(10)& SelObj1.Name
WinName1 = SelObj1.ReferenceProduct.Parent.FullName
MsgBox "* Catia Window Name *" &Chr(10)& WinName1
See if is it working...
Code:
Sub CATMain()
    Dim oDoc As Document
    Dim oPart As Part
    Dim oObject As AnyObject
    Dim cSelection ' As Selection
    Dim Status As String
    Dim InputObjectType(0)
    Dim sPath As String
    Dim i As Integer
    Dim oParent As AnyObject
    Set oDoc = CATIA.ActiveDocument
    Msgbox "This macro will find the path for an element in a CATPart"
    '### SELECT SOMETHING ###
    Set cSelection = oDoc.Selection
    cSelection.Clear
    InputObjectType(0) = "AnyObject"
    Status = cSelection.SelectElement2(InputObjectType, "Select an Element", True)
    If (Status = "Cancel") Then
        MsgBox "nothing selected.", vbInformation, "Error"
        Exit Sub
    End If
    Set oObject = cSelection.Item(1).Value
    cSelection.Clear
    '### END SELECTION ###
    '### FIND PATH ###
    i = 1
    Set oParent = oObject
    sPath = "/" & oObject.Name
    Do
        sPath = "/" & oParent.Name & sPath
        Set oParent = oParent.Parent
        i = i + 1
    Loop Until TypeName(oParent) = "PartDocument" Or i = 20
    Msgbox "sPath: " & Right(sPath, Len(sPath) - 1)
End Sub
Fernando
- Romania
- EU
Hello, Ferdo. Thanks for your script.
Your script can find the path in Catia tree..
I meant I want to find a path of a File in 'Sketcher' mode.. ex) "C:\Users\Desktop\Part1.CATPart"
Not "Product.1\Part.1\Geometrical Set.1\Sketch.1\Point.1"
I know only to use 'FullName' method.
But this can't work in "Sketcher" mode. And I must select a "Product".
Do you have some ideas? Please, be my HERO :)
I just tried to use below script. But I didn't get a result what I want.
Because I have a Product that has included a Part.
I have to know "01_101__Lower Insert Steel"'s file name, not a Catia name, when I'm in "Sketcher" Mode.
Code:
MsgBox CATIA.ActiveDocument.Name
MsgBox CATIA.ActiveDocument.Path
MsgBox CATIA.ActiveDocument.FullName
Interesting...if you will put the whole code in a CATScript will do the job, no mater what you will select and where you are active (Sketcher or what ever...).
Look more carefully at the code and follow his workflow, when you do the selection is "AnyObject" , then you will find the name of the parent of the selection... there are lines there which are not useful for your purpose (just to let you know it can be done also in different ways).
For me is working fine.
Code:
Sub CATMain()
    Dim oPart As Part
    Dim sPath As String
    Dim i As Integer
    Msgbox "This macro will find the path for an element in a CATPart, CATPart name and CATPart path"
    cSelection.Clear
        Exit Sub
    End If
    cSelection.Clear
    '### FIND PATH ###
    i = 1
    Do
        i = i + 1
    Msgbox oParent.Name
    Msgbox oParent.Path 'Full Path
End Sub
Fernando
- Romania
- EU
Hey, FERDO
Your script solved my problem!
You are my saviour!! You saved me!!!
Now I can sleep deeply and work tomorrow with smile!!! ;)
