Our company has had on-again off-again issues hitting elongation specs for a few customers (specifically one more than others). In some cases, our product underperformed and in some they have overperformed.
One instance we had a tech from a company come to us and show us how they perform their pull tests on the Nylon 12 tubing being ran for said company. During and even after a few hours of the run, our elongation %'s were around 30% below their low limit. When we shipped the product to them however, they had no issues and reported %'s +60 or higher than we or the visiting tech could get - they were in a bind an agreed to try the parts.
*I know pull speed / rate of travel has a large effect on elongation testing but are there factors / settings in the process that can change how the material stretches after the being extruded?
*Can nylon 12, specifically Vestamid ML21, be processed so that when it is still warm (during production), its at its maximum elongation and once reaching ambient temp and humidity becomes brittle and doesn't stretch as far?
*Can it be ran so that the opposite effect occurs? Once settling to temp & moisture equilibrium, elongation increases?
Like i mentioned earlier, we've had instances that went both ways were elongation seemed to decrease after the run as well as seeming to increase after the run. The company dose attempt to use the product in either situation and has seen mixed results. So before we do a deep dive and start a project I thought I'd ask some experts who may have ran into this before.
