How do I look ahead to see if I will have B axis cutting
Lvee
Industrial
Dec 12, 2013
6
I have a Toshiba 4-axis mill with B axis cutting.
M10 (clamp) & M11 (unclamp) B axis
M10 is the default state of machine, meaning table will always unclamp, rotate and clamp after rotating.
I do not need to program M10 & M11.
We have never programmed M10 or M11 because we have always left the machine in M10 mode.
We now have a job with a lot of B axis cutting, so now the problem is very obvious.
If I only cut X-Y-Z everything is great, as below.
(ROUGH_BOTTOM_FACE)
S764M03
G57H901
G00X-16.3258Y17.0828
G43Z65.77H001
B0.0
Z50.77
G01Z50.52F22.92
X-12.0598
X12.0598
X16.3258
Z50.77
G00Z51.47
If I cut with B axis, machine will dwell prior to B cutting because of unclamping.
So that my cutting tool dwell and chatter for about 2 seconds.
If I add M11 (unclamp) before of after B-315.6076 rotation, machine will not hesitate during cutting.
(FINISHT_WALLS)
S9004M03
G57H901
G00X3.0099Y13.24
G43Z66.7116H002
B-315.6076
Z55.3116
G01Z51.9793F57.5
X.0099
X.0121B-315.6001F92.5
X.056Z51.9798B-315.4477
X.1Z51.9797B-315.2952
X.1439Z51.9798B-315.1428
Here is my wish list
1) I do not want to use a UDE in the start of events to control table clamping.
It would be to easy to forget when to turn clamping on or off.
2) I want the post to look ahead during this operation of cutting up to the next operation.
if the B axis does not change during any linear cut, output M10 in my initial move or my first move
3) If I did cut with the B axis, output M11 in my initial move or my first move
4) Getting M10 or M11 after the B is the easy part, deciding on which one is the tough part.
I have tried this, but variable_axis does not always cause a rotary change.
if { $mom_tool_path_type == "variable_axis" }
Any ideas would be greatly appreciated.
Lvee
You should be able the activate the Auto clamping at the start of the program. This should turn on and off the clamping codes when the post detects a 4th axis move.
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6, NX7.5 & NX8.5
Vericut7.2.3
 http://files.engineering.com/getfile.aspx?folder=5314bf1e-a5cc-4f54-b306-46d26c186c42&file=clamp.JPG
I understand about auto clamp.
I want to set my clamp code relative to cutting that will happen during the complete operation.
Currently, I know that the unclamp code could happen in the middle of a cut.
The problem is that the machine will dwell waiting for the unclamp to happen.
I would want the cutting to start in unclamp state, with that the machine will not hesitate with any B cutting.
thanks for any input
Lvee
Are you using Post Builder?
You can use the several mom variables to check if the 4th or 5th axis has changed.
mom_out_angle_pos and mom_prev_out_angle_pos for example.
John Joyce
NX6, NX7.5 & NX8.5
Vericut7.2.3
I currently use these variables for the current cut.
What I would like to do is this
let's say my current $mom_operation_name is ROUGH_LEFT_SIDE_OF_AA
and all the cutting happens at B15.
I want to look up to the 2nd operation of cutting and know that the B axis never changed.
knowing that I would output a M10 in the first move or the initial move
my 2nd $mom_operation_name is ROUGH_RIGHT_SIDE_OF_AA
and all the cutting happens at B30
I would look ahead an do same as above, only use M10
my 3RD $mom_operation_name is ROUGH_CNTR_SIDE_OF_AA
this cutting has
X,Y cutting
X,Y,Z cutting
X,Z,B cutting, and so on.
I want to look up to the 4th operation of cutting and know that the B axis is changing during a cut only, not a rapid move.
knowing that I would output a M11 in the first move or the initial move
my 4th $mom_operation_name is ROUGH_POCKET_BB
I don't think the mom_nxt variables will help with what your looking for.
Sounds like a lot of customization is needed to accomplish what you are looking for.
John Joyce
NX6, NX7.5 & NX8.5
Vericut7.2.3
John,
Thanks for your input.
If I come across anything I will let you know.
Lvee
