Mar 5, 2003 #1 atiaran Chemical Feb 19, 2003 15 0 0 US I have nine 400 gallon totes of wastewater containing acetone (about 200 ppm) that I need to treat to remove the acetone so it can be discharged to the local POTW. Is there a simple effective way to do this? Thanks.
Mar 6, 2003 #2 aspearin1 Chemical Nov 5, 2002 391 0 0 US You could try activated carbon filters. Stong UV and Ozone might also be used to oxidize and break the carbon structure into CO2. Upvote 0 Downvote
Apr 9, 2003 #4 arbo Chemical Mar 14, 2003 7 0 0 BE contéact arbochim@online.be they will give you the solution Upvote 0 Downvote
