Pixy
- Mar 22, 2022
- 84
(the above are 4 baseplates with 3 painted with epoxy (for the inner side) and first few holes marked with pen and the 4th baseplate showing the unpainted side).
Do you use cardboard or big paper and punch against the anchor bolts to layout the holes in the baseplates to be drilled by the machine shop?
What are the proper way to layout it? The anchor bolt distances to edges are irregular but I found out that if I used measuring tape and mark the baseplate hole with a marking brush. The round hole is not even and the machine shop may not be able to drill it at the right distances. Tips? Thanks.
