How do you reduce the scale of a table?
SrGilberto
132
I have to update some drawings with a new format. The drawings have several tables and one (or more) are large tables. The text is easy enough to change, but I've had to change the row height's and column width's individually (enlarging them 2x). Is there a way to scale tables larger or smaller without having to change the columns and rows individually?
I'm using Wildfire 5.0
Thanks,
Gil
Select the whole column or row or complete table( highlight in green), and then right click, you will find option width and height, give the value in inches
