bojoka4052
- Oct 8, 2021
- 108
For example it tends to be colder at the opening, but warmer as we move further in? It would also make sense that the temperature only goes up a little during the summer, and a bit down during the winter months deeper inside the tunnel, compared to right by the opening; where I imagine the temperature would go up and down much more?
Edit: I ask because of joint sealant for concrete, I get too much displacement in the concrete due to rise and decrease in temperature. I am thinking this cannot be realistic numbers (5 mm) deep inside the tunnel. Maybe in reality the temperature is significantly lower.
