How effcient are current automatic transmissions
dadof275103
Automotive
I have just read that the Chrysler 904 Torque Flite is one of the most effcient automatic transmissions in use. Is this true?
How is this tested?
Are automatics still 4% to 6% less effcient than a manuel transmission?
Michael
dadof275103
"What goes around, comes around"...
I find it amusing that BrianPetersen posted "... NOWADAYS, it's a variable-displacement pump..." [re: automatic transmissions]. The original GM 4-speed Hydramatic first offered in 1939 (Cadillac, I think), and up through early 1956 (and even later in some trucks and Rolls Royces) all had a variable-displacement front pump. And they didn't need a lock-up clutch for cruising efficiency, as the fluid element (a 2-element coupling, not a torque converter) was out-of-the-circuit (just along for the ride) in 3rd and 4th gears.
I guess it's obvious that I'm a fan of the DualRange Hydramatic. I ran my first HydroStick (a DualRange modified for racing) back in '65. And I just recently built one for the pickup that I'm putting together.
Just for argument's sake, I'd love to work with a transmission-dynamometer shop on fixturing one of my HydroSticks to get some hard numbers on its efficiency.
It's interesting that auto tranny design went backwards before it went forwards again. I've heard of the early 4-speed automatics but know next to nothing about them. I think the Powerglide replaced them - 2 speeds with torque converter that was always in the circuit. 4-speed automatics didn't become popular again until the 1980's, nor did the capability of taking the fluid element out of the system during cruising.
I think that early 4A may have been fitted into some 1957 cars. Briefly (and many years ago) I owned a 1957 Pontiac, might have been a Star Chief, and it had the 347 CID engine with a 4 barrel carb.
Anyway, I found out it had four forward gears once I swapped in a set of straight plugs and solid copper ignition wires. It was amazing how well the AM radio took up the task of being an auditory tachometer.
Norm
Yes, Norm, your '57 Pontiac had a 4-speed Hydramatic. It was the 2nd-generation design called Dual-Coupling Hydramatic, first offered in mid-1956. It used a second, smaller fluid coupling to replace the front planetary clutch of the Dual-Range unit. The intent was to "soften" the 1-2 and 3-4 shifts- which it did- and thus wasn't useful as a modified race transmission (no way to instantaneously fill a coupling!). This secondary coupling remained in the circuit while cruising in 4th, so I'm sure it gave away some efficiency. I don't remember whether it retained the earlier variable-displacement pump.
Dual Range Hydramatic!
Yes 4 speed.
Yes vairable displacement pump.
Yes a lockup clutch
No Torque converter a fluid coupling instead.
Not sure how long offered in cars but I think they were still offered in trucks into the 60's.
The Dual coupling Hydramatic is a different transmission.
