how I can convert from the NM3/HR t
Amir Nagy
8
how I can convert from the NM3/HR to KG/HR for natural gas ?
And temperature.
Statements above are the result of works performed solely by my AI providers.
I take no responsibility for any damages or injuries of any kind that may result.
Well he said NM3/hr so the density needs to be at that pressure and temperature. Amir - Note that Nm3 is not fixed, but commonly 101325Pa and 15C/60F or somewhere close to it.
Sometimes, especially in the EU, but rarely in the US, "standard" temp might be 0°C
Use  PV = ZNRT
normal conditions    P = 1 bar  T = 15 ° C
Using equation you can transform NM3  to  Kg/Hr
You need the molecular weight of natural gas and with standart P Y T you will find density at this conditions
Density =  PxPM / ZxRxT  Check the right units for the calculations.
Horacio
Amir, Nm³ is a specific amount of mols (no matter what gas you are referring to): 0.02241 Nm3/mol or 0.0442 kmol/Nm3
So if you know your MW of the gas then you can easily calculate mass flow.
If pure CH¤ (18 kg/kmol)
1Nm³/hr= 18*0.0442= 0.803 kg/hr
This is of course assuming that you consider the most normal conditions: 1 atm and 0ºC but as others have mentioned normal is only "normal"....
Best regards, Morten
Sometimes which "standard" temperature and pressure you use makes the most difference.
