How is the life as a FEA/CAE engine
_namit_
1
How is the life as a FEA/CAE engineer ?
Life is usually OK while ever you are breathing.
Like any engineering job: It's a living... If you're careful:)
Mike
since FEA isn't always needed, and you're going to be spending more time just designing
Despite the simplification of lower-level analysis tools most companies still have dedicated analysts to do the heavy lifting. Some of those analysts even get away with refusing to do design updates and optimizations, every failure becomes a painful process involving a design engineer updating CAD, sharing files, and another round of analysis. The person who knows what needs done isnt the one doing. :p
I worked as an ME supporting an analysis group of over 20 analysts. There were zero "FEA engineers". There were material scientists and thermodynamics experts and mechanical engineers with advanced degrees (mostly Ph. D.s, fewer MSs). They used FEA to solve and analyze problems.
