themilkmaid
I'm working on a project that requires a heat sink for a high power LED. The unit shown in the linked images works well, the problem is that I can't figure out how it was manufactured and I need to create something similar but customized to this project.
This heat sink is from a fairly high volume product. The material is aluminum, and it's anodized. The part is not machined, there are very sharp inside corners that they would never bother with since they serve no purpose. There is 0deg draft on any of it, so it's not die cast. As far as I know you can't metal injection mold aluminum, so that's ruled out. There's no way a high volume part would be sand cast.
Am I missing something? Is there some sort of automated high volume equivalent to sand casting? The bottom face is smoothed with a secondary operation, but the rest of it can be a bit rough. I have Googled everything I can think of with no success.
Any ideas?
Any ideas?
