Lion06
- Nov 17, 2006
- 4,238
I recently got to run my own project for the first time. It was a very small project, but I was the one coordinating with the architect and doing all of the detailing/design.
This is a question for the experienced engineers out there. How much of the calculations that changed during design do you keep for the project?
Just as an example, I designed some clips to support a 17' strip window 6" from face of wall. Initially these clips were carbon steel (Fy=36 ksi) with a width of 3" (for architectural considerations) and I designed the thickness to be 1/4".
Then the architect changed it from carbon steel to stainless steel (Fy=30 ksi) and it needed to be 4" wide with 1/4" thickness.
Then I talked to the glass guy to get an idea of how much bearing width they want to see (turned out to be a minimum of 4") and found out that they don't like to use SS greater than 3/16" so they can maintain a tight radius on the bends (It was a bent plate).
The final product ended up being a 3/16" thick x 5" wide bent plate. After all of that, I have three different designs for this one simple bent plate.
I am sure others have been down this road with similarly small things (and I am sure with larger things).
The question is whehter there is any reason for me to keep the first 2 designs for the bent plate with my organized project calculations or if they can just be tossed out.
Any insight here would be greatly appreciated.
