how prevent displacement normal to a surface
juan1989
4
Hi all,
When the displacement we want to prevent is parallel to a cartesian axis there is not problem.
The problem is when I want to prevent a normal displacement of a surface no parallel to a cartesion axis and even when the surface is not straight.
How could we prevent the normal displacement in those cases?
Thank you!!!!!
I supose, just in case of a straight surface is creating a new "CSYS" coordenate system in the correct position and then, we select it and we can do it.
Am I right??
but in case of a random curve surface how we would do it??
Same idea, but generalized.
Create spatially varying local CSYSs and specify appropriate kinematic constraints in the required directions.
Are you new to this forum? If so, please read these FAQs:
Probably it is not possible what I proposed
That's only possible trough contact.
Make a copy of your surface; make it rigid; define contact; deactivate 'Allow separation' in contact property.
