jonathan8388
Aerospace
Hello everybody,
I am looking for some help from somebody who is very familiar with statistical tolerancing for a question that I have. It is a long winded question, so please bear with me. I work in the aerospace industry in rocket propulsion as a design engineer. I am currently working on the tolerance analysis for portions of our motor design and have been using both the "Dimensioning and Tolerancing Handbook" by Drake, and "Mechanical Tolerance stackup and Analysis" by Fischer extensively for my work. I am currently doing the work in excel under a traditional +/- tolerancing technique, which has been pretty simple for the most part. There are a few stackups that I am encountering with 15+ contributors that yield extremely large variations in gaps in worst case, so I began experimenting with statistical tolerancing using the RSS method for a few select gaps. This has also been pretty simple for most dimensions, but I am having trouble figuring out the right way to factor MMC or LMC modifiers into the +/- stackup report for the statistical work.
Both the "Dimensioning and Tolerancing Handbook" and "Mechanical Tolerance stackup and Analysis" texts show how to account for the MMC and LMC modifiers in a +/- spreadsheet format, but the problem I am having is that they conflict each other, which effects the final RSS tolerance. As a general example, let's say I have a hole with the following dimensions that I need to add into a stackup spreadsheet:
Nominal Diameter: 1.000"
Diameter Size Tol: +/- 0.100"
Positional Tol: 0.05" @ MMC
The book by Fischer will split these tolerances into three different lines in the spreadsheet: one for the hole size tolerance (+/- 0.100"), one for the positional tolerance @ MMC (+/- 0.05") and one for the bonus tolerance ( +/- .200") and use these three separate tolerances to compute an RSS.
The Dimensioning and Tolerancing handbook, however, states that you need to first find the Resultant condition (in this example, 1.35"), find the Virtual condition (in this example, .85"). Then, find the midpoint of these two and convert to an equal +/- tolerance, which would be 1.10" +/-.250". This book states that this 1.10" +/-.250" is what actually needs to be used in the spreadsheet. If use this single .250" tolerance in an RSS and compare this to the way Fischers book does it (breaking it out into three separate tolerances), I get the same worst case, but I get different statistical values for the total assembly gap tolerance.
Does anybody know the right way to account for this bonus tolerance in an RSS analysis? Should I split things up in the stackup like Fischer does, or should I combine into one line like the Dimensioning and Tolerancing handbook does?
Jonathan
Jonathan
