how to add method in NX shop Doc
weiber
Automotive
Nov 21, 2011
4
hello,
in postbulid,
global mom_stock_part
if {[info exists mom_stock_part]} {
if {$mom_stock_part < 0.03} {
MOM_output_literal "finish"
} else {
MOM_output_literal "Rough"
check stock export finish or rough is ok,but shop doc is error
Someone can help you
Is the mom variable defined at the point you want to check it in shop docs? You must be cycling the operations or methods to get this variable.
If you turn on the review tool in shop docs, you can see all the events that are produced by the cycling, and all the variables set by each one.
Then you will know exactly what variables you have to work with.
Mark Rief
Product Manager
Siemens PLM
Hello Mark
How do I shop doc build method so that those who know the machining process in the processing of rough or finish.
thank you help.
Hi Mark
so ,How do I set up in the shop doc roughing finishing mode processing
please help me thank you
Sorry, but I don't understand the question enough to offer much more help here. If you are not experienced with customizing the shop doc templates in tcl, please contact GTAC or your reseller.
Mark Rief
Product Manager
Siemens PLM
