johnsonSDSMT
- Jun 10, 2004
- 9
I am designing a strong back beam that will be holding a 100 kip truck bed up. The beam must be lifted by a crane and there are severe height limitations on the overall system so a oval shape must be put in the center of the beam in the web. It needs to be 20" in depth and ranges from 5" to 8" in diameter.
Also the above flange needs to be removed for 20" directly above the web opening.
My inital thoughts are to basically readjust my section properties (Ix, Zx, Sx) by taking into account the effective area of the flange and web with these missing parts and then just do my Shear, LTB, FLB, WLB and yielding checks.
However I am wary that the web opening may be to big to treat it like a normal "hole in a beam". My text book references a design guild specifically for large web openings however I am working for a company just for the summer since I am starting grad school in the fall for my masters in structural engineering so I am not really in a position to get this book and unfortunatly the engineering department here is more project engineer then design so there is no one with any experience in this more detailed analysis.
Any fast and dirty methods would be appreciated, I am already taking my factored load moment and multiplying it by a F.S of 1.5 to provide extra safety since the loading is dynamic to an extent and I am also planning on having plates welded around the area that will be extruded.
If I do it the way I mentioned above I am having some difficulty in calculating my new Zx, but I have my new Ix and Sx. Thanks
