As-Lag
- Aug 6, 2019
- 56
Hello
I want to check the strength and serviceability of a concrete raft foundation. The raft is bascically a reinforced concrete ring-beam supporting a reinforced concrete slab.
Given the ground supporting the raft may move due to tree-roots, how should I apply my loading onto the ground? For example; if I assume the ground beneath one corner of the raft sinks or rises, I assume I would check the edge beam for cantilever action. Similarly, the ground beneath the centre of the long beam shrinks so I check the beam for sagging. Are there any rules, standards or examples to guide me?
Any help appreciated.
