Hi All,
I have a load test machine where I set a regulator to a certain air pressure which translates to a specific force on a pneumatic cylinder.
For example, 10psi on the regulator would equal 100lbf on the cylinder
So, if I want to carry out a load test on a component I set the regulator to the value I require and test the component.
The problem I would like to address is that at the moment the machine instantly goes to the test force as opposed to pulling the load on slowly.
I know that I can use a speed controller to control the speed of the cylinder when the load is applied but how can I control the rate at which the force is applied?
Hopefully this makes some sense.
