How to apply floor deformation when the aircraft floor is in an angle
Oded.Mizrahi
Aerospace
Jan 13, 2023
Hello
I am planning a dynamic test according to 14 CFR Part 27.562 and SAE AS8049C for rotorcraft seat. the floor and tracks in this rotorcraft are not parallel to the water line (horizon) but elevated at an angle of 3 degrees.
The question is how to aline the axis of the floor deformation fixtures.
should the roll deformation axis be alined with the floor track or be alined with the horizon/longitudinal axis of the aircraft?
Many Thanks
Oded
I'm not sure if a Part 27 rotorcraft will use exactly the same procedure and guidance as a FAR 25 fixed wing, but I'm referring to AC 25.562-1 for my answer.
The deformation of the beam is made relative to the original position, per Figure 9-1. That makes it pretty clear to me that the original orientation of the beam, either in parallel with the aircraft horizontal plane or at an angle, is the starting point. This is a little different from the text of paragraph 9, therefore I can see how you might be seeking clarification. However, by considering that the vast majority, if not precisely all, fixed-wing transport category aircraft mount their floors horizontally, then it's no surprise that they would mix up "horizontal" with "longitudinal axis" as equivalent. Some exception in a different category of aircraft is not going to cross the minds of the people who wrote the guidance.
Sparweb,
Thank you for your answer.
I will proceed as you described since it is also stated in AS8049:
"The roll beam shall be capable of ±10 degrees roll about the centerline of floor tracks or fittings"
Oded
