Yes sure.
I want to validate the results of experiments about distortion of Strips (70*20*3 mm).
I need defining initial stress to defining stress induced by great blasting (before the main process: cold spray coating).
I have calculated the stress induced by grit blast by using distortion of the strips.
I mean that I measured the distortion of strips, then changing it to curvature and calculating the stress by using some formula.
I need some way to make stress inside the part. Dosen't matter how.
If it was a bie-metal it was possible to do that, by defining different initial temperature for two part. But in my case it is only one part, since it is before coating (just after great blasting)
