We have an atmospheric API storage tank, venting to atmosphere that receives deionized water and goes from it to mixed beds.
It has no protection against CO2 entering the tank with the air during pump out.
Which options do we have to avoid it ?
1) We tried N2 blanketing but don't want to loose it. In that case we should install a system to control inside pressure and N2 flow in-out and a PVRV to protect the tank if the N2 control system fails.
1a)Which should be the pressure inside de the tank ?.
1b)How can I calculate flow of N2 ?
1c)Which should be the set point for the PVRV.
2) Has anybody tried to filter the air through Sodium Carbonate?.
2a) How to calculate the filter and the required volume of Sodium Carbonate ?
2b) How can I determine when to change the Carbonate ?
2c) During pumping in, will the air pass through the filter bed counter currently with no problem?
Answers to my questions and any other options will be very much appreciated.
Thanks in advance
Thanks in advance
